Dissolve / dust setup
Post by Maximus » 12 Jan 2012, 22:46
Hey guys, anyone knows a reliable and not too complicated way to achieve this kind of effect?
http://www.youtube.com/watch?v=g9xbGQfvbb0
the idea is to have 2 objects one on top of another, the outer one gets dissolved revealing the inside one.
so for the dissolve force i was thinkin about wind or something, it needs to be done with same material/textures on the geometry.
I saw the caffeine abuse dissolve tutorial but was lookin if there was an alternative solution.
Thanks for any input.
speakin about simulation, not rendering/shading btw.
Tekano
Re: Dissolve / dust setup
Post by Tekano » 12 Jan 2012, 23:01
this tutorial by Brad Gabe pretty much covers all that you would need for a simple to setup effect like in that krakatoa vid.
You could camera project an image (or render) onto your outer hull and read the nearest location>texture and use that to colour your particle.
Post by Maximus » 14 Jan 2012, 05:15
Thanks a lot, that was really a good one :)
Post by origin » 14 Jan 2012, 12:10
standard dissolve effect you see in all those videos is turbulence. you can also try curl noise framework for cooler effect
Post by Bullit » 05 Feb 2013, 19:53
This effect is nice but how to achive this with a moving hand/object?
The particles that should stick don't stick if the object is moving...
Edit: disregard i wasn't putting into the root.
