Momentum3 issue
sugnsu
Momentum3 issue
Post by sugnsu » 06 Jan 2012, 07:09
Is "Momentum" can possible to like below video?
http://vimeo.com/34648196
This video is record of 3Dmax Thinking particle.
Important issue from this video is seemed like viscosity motion.
Re: Momentum3 issue
Post by EricTRocks » 06 Jan 2012, 09:00
I believe you'd be able to do this using Momentum. I haven't used Momentum extensively at all but from other demo vids and the tutorials you can set the velocity on the shattered pieces using ICE. It may be some work to tweak the effect to your needs but I'm highly confident someone with a good amount of experience with ICE could do it.
Eric Thivierge
ace63
Re: Momentum3 issue
Post by ace63 » 07 Jan 2012, 15:42
This should easily be possible using Momentum
CiaranM
Re: Momentum3 issue
Post by CiaranM » 09 Jan 2012, 12:07
Sure, you just need to make use of linear and angular damping. You can animate this per island for some nice effects.
Example scene:
http://dl.dropbox.com/u/14344332/3D/XSI ... usters.zip
