opening the Render Tree of the Current Pass
edschiffer
Post by edschiffer » 31 Dec 2011, 16:08
Hi all,
I'm learning python and as an exercise, I'm trying to make a script that opens the Render Tree of the Current Pass, without losing the current selection. so far it goes:
app = Application
sel = app.Selection
curSel = []
for obj in sel:
	curSel.append(obj)
app.SelectObj(app.GetCurrentPass())
app.OpenView("Render Tree", False)
app.SelectObj(curSel)
the strange thing is that when it opens the view, it says that "Update can't be done with two objects selected", as if it were reading the last line before the Render Tree is finally opened... (if I comment the last line it works, but doesn't get the selection back)
is it common?
should I be doing anything different, like XSI.Collection?
how to overcome this?
many thanks,
Re: opening the Render Tree of the Current Pass
Post by xsisupport » 31 Dec 2011, 20:10
The view is opened after the script finishes executing, that's why you get the message in the Render Tree.
Not sure that there's a way around this, except maybe using a timer event.
I'm pretty sure I've seen this before, but it's been a few years...
I didn't try putting that script into a custom command to see if that made any diff.
// Steve Blair
edschiffer
Post by edschiffer » 31 Dec 2011, 20:38
I tried time.sleep(), but it only slowed down the opening, as you mentioned...
tried putting the .OpenView under a loop too, but got the same results.
OK, at least it's good to know it's not only a slip of mine...
