I have C# application and I want to pass value from it to a custom Ice Node in reel time
anyone can help me to do this?
How to pass value from application to custom ICE Node?
mjd3d
Leo
Re: How to pass value from application to custom ICE Node?
I'm not an expert on this kind of interaction, but my intuition tells me that it would be easy to just write the information to an xml (or other) file and read it from the icenode.
There might be a better way of doing this, but that would definitely work.
Also more of a workaround (I guess), but you can always set the value äs it appears in the ICE Tree...
This is Pythonesk, but it's just to illustrate: ;)
Application.SetValue("cube.polymsh.ICETree.3DVectorNode.value_y", 2, "")Stay safe, sane & healthy!
Leo
Could you elaborate on that? I'm not really sure how an application could set a value in Softimage.Hirazi Blue wrote:Also more of a workaround (I guess), but you can always set the value äs it appears in the ICE Tree...
This is Pythonesk, but it's just to illustrate:;)Code: Select all
Oops, I read "application" as meaning "plugin" not "external application", in which case I don't think its possible... ;)
