Image I\O From ICE
Image I/O from ICE Originally developed for testing his Implosia FX toolset, Mr. Core recently released
these compounds that let you import and export image (.BMP/.TIFF/.PNG/.JPG) and mesh
files (.OBJ, UV not yet supported) within ICE.
For image handling, this package includes the Build PCloud from Image compound that converts the output array from the IFX Read Image node into a pointcloud, which can be further modified by ICE and then written back to an image file through the factory build array from set node plugged into IFX Write Image. This allows a PixelParticles-like workflow (see the PixelParticles description further below), for example for image manipulations inside ICE.
The local backup archive contains all files collected from the si-community thread
(see below) including some additional compounds by Fabricio Chamon which handle file
name/format string conversions. To install, copy the .xsicompound files into the Data/Compounds
folder of the USER or a workgroup/addon directory. The .dll file goes into the Plugins subfolder —
a demo scene file is included.
Related plugins: Pixel Particles, Image ICE Node
local backup: ImageIO_packed_1.0.zip
Mr.Core
- Skype: giga-core
Image I\O From ICE
Hi!
Just a simple set of custom nodes to get ability write\read Images ( bmp\tiff\png\jpg ) and wavefront .OBJ files ( currently only point positions and polygonal description without a textures and matID ) from ICE ( yes, I know that it useless in 95% cases, but probably will be nice as a toy, I am personally using it for imposia's debugging purposes ). Have a fun!
x64 only, tested under 2012\2012.5
Download here
Probably will be necessary to donwload a vs2010 redistr from here
Download here
Pooby
Re: Image I\O From ICE
ooh.
can you get closest location etc from the pixels? How does it work if there are no points or particles?
It looks very interesting indeed, but what can it do?
Mr.Core
- Skype: giga-core
It reads image from disk and outputs as array of colors, from the left to right and from the top to bottom ( x1\y1 // x2\y1 .... xWidth \ y1 ................ x1\yHeight ..... xWidth \ yHeight )
Of course you can get closest location\raycast if you apply this array to point cloud grid
Pooby
I see. So how do you write changed colour values back to the image?
Also, whats the installation procedure? Im useless with plugins
Without having tried this myself (yet) and merely looking at the rar-file, I would assume, you'd have to drop the dll into the "Application > Plugin" folder in your Softimage User directory or your preferred workgroup... I assume you can get the necessary ICE Nodes out of the included scn-file and would have to resave them in an appropriate location.
(But that's just guessing, as I haven't opened the file yet).
Mr.Core
- Skype: giga-core
BY the node called "IFX Write Image" wich is get three arguments - width\height and array of colours. You can modify colors by two ways - 1) apply it to point cloud and further works with points as with pixels and 2) do direct processing by usage of some logical trick with the indexation of arrays ( nodes like modulo\divide\round etc )
The installation procedure is exactly what Hirazi said, except resave because there are no additional compounds
list of nodes in this dll:
IFX Read Image
IFX Write Image
IFX Read OBJ
IFX Write OBJ
IFX Read Image
IFX Write Image
IFX Read OBJ
IFX Write OBJ
The scn-file crashes on me each and every time I try to load it.
The ICE compounds seem okay though,
if only I knew what they are meant to do exactly...
Mr.Core
- Skype: giga-core
Did you got any error mesage on crash ? And what is your version of xsi ?
basic description of nodes
READ IMAGE
inputs:
File Name: - image file name including full path
ActiveProject as root: means that actual project path will be added to image file path ( like "D:\\"you_proj_path_name\" + image name which you put )
outputs:
Raw pixels: - array per object of colours ( each element = 1 pixel, pixels are readed from the left to right and from the top to bottom )
Width: -width of image ( number of pixels in horizontal )
Height: - height of image ( number of pixels in vertical )
WRITE IMAGE
File Name: similar to previous node
ActiveProject: also similar, but new image will be created in "your_proj_name\Render_Pictures" folder
Width\Height: - similar to previous
Color data: - array of colors per object to store it to the result image ( array of pixels )
Enforce Evaluation: - this port must be evaluated to get node aslo be evaluated, there are two ways to do it - 1) connect to node "Log values" and 2) show this attribute in the viewport
READ IMAGE
inputs:
outputs:
WRITE IMAGE
Thanks for the description...
I tried to load the scn-file into SI2012 SP1 and my current SI2012 SAP and I didn't get any error messages. Strangely it happens while SI is (re)creating the layout, as the explorer shows the loaded objects already...
TwinSnakes007
What class in the SDK are you using to write the image out?
Mr.Core
- Skype: giga-core
I am using third party libs for that, not si SDK
I don't see the IFX Assembly Sequence Name node in the ICE tree at all. Is there a way to use the standard tools to get it to write out an image sequence based on the frame? I'm not reading a sequence in, I just want to write out my own from scratch. I'm able to write out a single frame which is awesome.
This is definitely an awesome plugin!! Thanks so much!
Something else that would be cool to have, is a node that autmatically builds a point cloud in the correct order and a node that builds the color array in the correct order from that pointcloud. Just tossing out ideas.
Mr.Core
- Skype: giga-core
It is just a simple compound that I builded from factory nodes
That is very simply to implement, fisrt case I have attached as compound called "Build PCloud From Image" , and in the second case you can just use "build array from set" node to get array of colors and connect this array to "Write Image" node
Awesome got it working! Thanks so much. Just did a simple setup using a null to modulate the color of particles inside it and output the sequence of the null moving from one side to the other.
I have to say this is really fast as well. Just played back the timeline and it zipped along as if it wasn't doing any extra calculations.
Great job! Now I just have to figure out or dig up a compound that what pixel particles does and stick some particles to a mesh via UVs and we have a custom "pixel particles" setup.
Also anyone who is thinking of doing an ICE based renderer has an option now too.
fabricio.chamon
Man, this is soooo awesome! thanks a lot Mr. Core.
all kinds of image processing inside the ice tree! that's fantastic and will surely open up for a lot of possibilities.
here's a quick image blur test, along with 2 compounds that might be useful to some of you.
"Change File Name" compound: changes or appends file name of a file path input with option to keep or change extension.
(also outputs a no extension string to be fed into IFX Write Image, since it appends the format itself)
"Get IFX File Format from File Path": outputs an integer to be fed into "Format" port of IFX Write Image.
bmp = 0, jpg = 1, png = 2, tiff = 3 (defaults to bmp in case of unsupported file format)
I can't thank you enough!
