snap rotation? not incremental snapping rotation
pablogv
Hello, I'd like to snap the polygon of the image to the ground by rotating around its center axis -in this case at the botton of the polygon- but snapping options don't work. Snapping do work with translation but I need with rotation. Any help? Thanks
Re: snap rotation? not incremental snapping rotation
You probably mean 3 point rotation known from cad soft? I dont think there is such tool built in xsi.
pablogv
Yes, I've just seen Autocad tip "Rotate One Object to Match Another" and that woul be great. I cant believe there is no such tool in SI... Thank you!origin wrote:You probably mean 3 point rotation known from cad soft? I dont think there is such tool built in xsi.
It could be done with a direction constraint. Snap 2 nulls to the end points of the edge you want to rotate around, and snap a third null to a point of the object that's supposed to be on the floor.
* make a direction constraint on one of the edge nulls, pointing to the other edge null. From the constraint property page, pick the third null as the upvector object.
* parent the object under the null that has the constraint
* move the third null, snap to floor
pablogv
Thank you, rray! I will try your advice.
pablogv
Sorry, but I still couldn't make it. I'd like one object snap to other by rotating. I'm posting an image with a simpler example.
The second problem you posted is more complicated and can't be solved that way (Built-in snapping tools can't do it either)
First problem you posted however can be solved using the steps I posted before.
pablogv
Sorry. I was looking for a solution to the first and second problem. A rotation snapping tool or plug-in, something like that.
The second problem would require intersection snapping, which Softimage doesn't support (You'd create a circle and snap to the intersection of the circle and an edge)
pablogv
Yes, both first and second problem would be easily solved with a intersection snapping while rotating tool. However, Softimage does support intersection snapping while translating. Am I wrong?
No, snapping to intersections of elements isn't supported at all (C4D, Max, Maya don't have it either (a.faik), it's more of a CAD software feature)
pablogv
I meant Softimage supports snapping to intersections of components or objects when translating. If you activate snapping, you can translate one component or object towards other and when they intersect it will snap. I don't know why it doesn't happen when you rotate an edge, for example, and it reach other...
Ah ok there's a misunderstanding.. With "intersection snapping" I didn't mean the normal snapping - I meant snapping (for example) a point to the intersection point of 2 curves. This isn't supported but would be required for your second example.
The normal Softimage rotation tool doesn't know which point of the object you want to align with the rotation - so snapping couldn't work. It would have to be implemented inside the rotation tool which is difficult to do in an intuitive way for the user.... I think I'd prefer a setup like mentioned before - more versatile (For example you can use any axis to rotate).
Would be nice to have intersection snapping though for cases like in your second example.
scaron
i believe this could be done as a custom tool, just like modo's rotation snapping. i will see if i can whip up a prototype.
s
s
pablogv
Scaron: I will build a monument to you if you did that custom tool! Anyway thank you very much for just triying!
