What's the difference?
iamVFX
Between "While with Counter" and "Repeat with Counter"?
Re: What's the difference?
The way I understand it, the "While with Counter" gives you the opportunity to set any kind of condition resulting in a boolean True or False to terminate the loop, while the Repeat sets a fixed amount of times the loop goes through. So the "While with Counter" only terminates after the certain condition turns False (or the Max repeat is reached), while a "Repeat with Counter" loops through its loop an exactly predefined number of times...
iamVFX
So if I work with a topology and use "While with Loop" with Max Repeat value that determined by number of polys - it's will be the same as if I used "Repeat with Counter"?
But you'd still have to set a condition...
In that case "Repeat with Counter",
where you "pipe" the number of polygons
into the number of repeats (+1? I forget...) seems "easier".
iamVFX
+1, exactly.Hirazi Blue wrote:But you'd still have to set a condition...
Ok, so difference only in the possibility of using the condition. Thanks, Hirazi!
The counter in While with Counter is a convenience. It's there so you can use it in the body of the loop, but as mentioned already, it doesn't control the number of loop iterations (unless you use it in the condition).
iamVFX
Thanks, Stephen! It's clear now
dwigfor
If you haven't seen this Modulo tutorial, you should look it over. https://www.si-community.com/forum/viewtopic.php?f=41&t=1842
I think it might help you eliminate the need for repeat with counter.
iamVFX
No, because for some reason merge vertices and cap hole compounds accepts only per object arraysdwigfor wrote:I think it might help you eliminate the need for repeat with counter.
