How to Close Softimage with out a Saving Question..
islasyr
Post by islasyr » 04 Aug 2009, 11:46
Hello..
I have a little problem..
I need to Close Softimage by a command, When I've used (Quit) command a question of Save confirmation appeard every time..
So how can I force Softimage to close without this question ? :-\
Maybe if I could reach PID of Softimage in Windows I can kill its process by a "Taskkill" batch command.. :ymdevil:
Any Suggestions?? *-:)
Thanks..!
Re: How to Close Softimage with out a Saving Question..
Post by Hirazi Blue » 04 Aug 2009, 17:07
But why would you want to?
Killing the PID from within the application itself doesn't somehow seem to be very wise... ;)
islasyr
It's all about Restarting..
Post by islasyr » 04 Aug 2009, 17:40
Well..
I'm developing an addon that can updates itself by checking for a new version on server every time that Softimage starts up, and before any action that user takes..
So after updating I need to restart Softimage for better results..
That's it..
Please if u have any idea to restart Softimage..
owei
Post by owei » 04 Aug 2009, 17:56
Hm...the only way I can figure out, is saving a scene (for example as "null_scene") and then quitting Softimage via script. If saving is performed right before you hit the quit button, Softimage does not ask again to save the scene. Unfortunately I can´t find a preference concernig this issue...at least, this could be a workaround...
cheers,
oliver
Post by Hirazi Blue » 04 Aug 2009, 18:46
Putting the update sequence in a startup event isn't an option? :-\
islasyr
Post by islasyr » 04 Aug 2009, 19:01
Sorry it's not Just like this..
When u save your scene as a temp_scene or something like this and run a QUIT command Softimage will get it as a Change and asks again to save :( ..
I've try it again and again but.. @-) no result..
So it's not a solution..
islasyr
Post by islasyr » 04 Aug 2009, 19:10
Mr. Hirazi Blue:
It's already in a startup event.. but after updating I need to restart Softimage and here comes troubles that I mentioned !!
I need to launch another Softimage and kill current one after updating my Addon..
I think it's the best way to restart the Application without errors..
Thanks really for your suggestions... :ympray:
Letterbox
Post by Letterbox » 04 Aug 2009, 20:06
Why not just pop up a dialog and ask the user to restart the application to complete the install of the addon.
islasyr
Post by islasyr » 05 Aug 2009, 10:24
Thanks Mr.Letter Box for ur Suggestion but here is the Power..
to restart Softimage by a Command.. That is the Challenge..
Thanks again..
