Octane render or not?
curly
Post by curly » 20 Nov 2011, 09:44
I'm looking at the website of Octane Render and thinking this might be it. The problem at this moment for Softimage users is that you have to export to a Renderman RIB file format to render character animation with it. You can purchase a license of 3Ddelight and export to RIB, but otherwise their is no way to use it for character animation. In upcoming versions they seem to release it with instancing subsurface scattering. Their are some very good export tools for it to work with Softimage. But for rendering character animation you still need RIB export. I'm not a coder, so.
It has depth of field etc... It has everything we all like in professional 3D renders. Any suggestions, or has someone used in for rendering character animation?
Re: Octane render or not?
Post by Hirazi Blue » 20 Nov 2011, 10:41
I don't know about Octane, but the free version (limited to 2 cores) of 3Delight does give you the possibility to export RIB "out of the box", so I imagine, there would be no need to buy a full license, if you only use it as a RIB-exporter, as you won't be bothered by the 2 core limitation in that case anyway...
From the 3Delight download page:
The downloaded software comes with one full license for free with no restriction for commercial use and is not time limited.
Post by Mathaeus » 20 Nov 2011, 16:24
curly wrote:Hi,
As Hirazi said, free version of 3delight for SI is limited only in final rendering. Actually I think the all other processes aren't limited at all - baking, exporting to RIBs, so on. About subsurface on instances, it works too. In case of ICE point cloud instances, you have to apply 3dl attribute to Point Cloud instead of instancing master, that's all.
Even I'm not sure these RIBs will render in other Renderman renderers 'just that', without issues.
Btw I've used both Mental Ray and 3delight and few others, for characters. If you ask me what renderer was best for characters, I'd say 3d studio Max Default Scanline, ten years ago :) - it was fast and simple, and clients weren't been so picky in these times....
PeterCGS
Post by PeterCGS » 21 Nov 2011, 22:15
From what I know RIB wont make it into Octane. They are currently making it so your host application talks directly to Octane (Viewport rendering) thus making any export pointless.
For now though, there is a very solid Softimage Soft2Octane exporter, surely being very effective for character animation work. You won't get motionblur, but you get the rest. I've been using Octane for all my animation work this last year, and it works great. The dog in this spot is for example rendered in Octane just for the fun of it: http://vimeo.com/26580519
Exporting ICE stuff isnt tricky either: http://vimeo.com/24566771
And comping it with other passes from XSI works great aswell for dust etc (car rendered in Octane): http://vimeo.com/28063417
Newcomer alert: please use the URL tags - HB
Post by ActionArt » 22 Nov 2011, 13:48
I'm very excited to see how that turns out, it would finally make it very useful for SI. Any rough timeline for when this might be available?
PeterCGS
Post by PeterCGS » 22 Nov 2011, 14:10
The 3DSMAX version is in Beta stage from what I know, and the others will follow shortly. I guess something will be shown atleast before the year is at end :)
Post by ActionArt » 22 Nov 2011, 15:02
Awesome! Since SI has no intention of including IRAY I think there's a great opportunity for Octane to jump in and fill that need.
No matter how great a render engine is, it's 100 times better when it's fully integrated. Looking forward to it :)
Chris_TC
Post by Chris_TC » 22 Nov 2011, 15:52
I would like to see a direct Octane plugin.
EDIT: Post edited in order not to spread misinformation.
Post by ActionArt » 22 Nov 2011, 16:09
Dang! That would rule me out too. I really don't like having to be connected. I work off the grid quite a bit.
PeterCGS
Post by PeterCGS » 22 Nov 2011, 16:39
This was the case many months ago, during the beta cycle. Now you only activate online ONCE if you move your license to a new machine.
You don't have to be connected after that.
They use the same online check philosophy as autodesk or Adobe and all other companies, so no need to worry. BUT its even nicer than adobe etc, because they let you change machine every 30 minutes if you like, deactivate and activate it on a new machine. After the change, you dont need internet connection.. So its all good!
Post by ActionArt » 22 Nov 2011, 18:17
Good to hear!
Post by Hirazi Blue » 22 Nov 2011, 19:10
My 2 cents:
Sorry, but it's a ridiculous system: if there is a valid reason why your pc isn't connected to the internet, having to activate a certain software doesn't make this valid reason simply go away. I like (more or less) the current system Softimage employs using hardware-related generated codes you can take to your nearest internet connection way better than the idea of having to move my workstation to the nearest internet connection in my house...
The things some companies come up with to get you to activate the stuff YOU bought, say a lot about these companies themselves, I'm afraid...
PeterCGS
Post by PeterCGS » 22 Nov 2011, 19:28
Well, ridiculous or not, I quite like their current implementation with a live database of materials created by other users that I can simply drag-n-drop in your scene. There is more to the internet connection than just the licensing part thats quite nice ;) Of course everyone has their preferences on how the licensing part should work. But the post about that you need to be connected to internet all times in order to run Octane, was false and I felt I had to chime in here to clear things up.
Chris_TC
Post by Chris_TC » 22 Nov 2011, 20:13
PeterCGS wrote:This was the case many months ago, during the beta cycle. Now you only activate online ONCE if you move your license to a new machine.
Oh, so they changed this? That's great news!
TwinSnakes007
Post by TwinSnakes007 » 22 Nov 2011, 22:35
Yup, looks like they backed off on having to keep a connection in order to render, here's a quote from their web store:
Note that all versions of octane render as of v1.0 beta 2.52 and higher will require an internet connection to be present during the license activation stage only, and for sharing content with community users. If you do not have an internet connection on the machine you are planning to install Octane Render on, you should consider getting a low speed mobile connection, or any other temporary connection to activate the software during the first install. Once the software has been activated online, you can run it without an internet connection, although you need it again to upgrade the software, or use the online sharing features.
I dunno, I mean, it can give great results, but at the cost of time and investment. The images in the gallery are run on between $500-$800 worth of GPU cards, and it still takes 3 hours to resolve.
