Is it possible to solve a collision for an object inside of another object?
As test, I'm using a small cube inside of a larger sphere. These are rigid deformers, not soft bodies.
My initial tests have all objects shooting off screen on the first few frames since, I'm guessing, that
there is an initial collision where the outer object tries to move the inner object outside of its geo.
Momentum - object inside object possible?
Chris_TC
Re: Momentum - object inside object possible?
You'll certainly have to give the outer object thickness, so that it becomes hollow on the inside.
