Hi all,
1 - I have an object with a texture map apply to it.
2 - I have points cloud generated from ice that reproduce the mesh object ( the object is not an emitter)
3 - I want the particles points to have the color of the texture of the object based on the nearest location
Unfortunatly, i've try several technics without success.
Do you have an idea how to do this?
Thanks,
How to give particles the color of a map texture from a mesh
didier13
Chris_TC
Re: How to give particles the color of a map texture from a mesh
You have to apply the particle color in the render tree. Load the attribute with an attribute color node and connect it into the diffuse port of your shader.
didier13
Ho yes. Now it works.Chris_TC wrote:You have to apply the particle color in the render tree. Load the attribute with an attribute color node and connect it into the diffuse port of your shader.
Here's the result on an apple:
Thank you very much !
