SlideOnSurface-Compound und Animated Geometry==Bad Idea
booyabase
Post by booyabase » 28 Jul 2009, 14:41
I want to use the SlideOnSurface-Compound with a animated geometry, but ICE does not work properly. particles fall through and stuff like that.
SlideOnSurface seems only to work on static geometry. The help about it says something different. Does anybody have a solution for this?
Martin
Matic
Re: SlideOnSurface-Compound und Animated Geometry==Bad Idea
Post by Matic » 31 Jul 2009, 16:47
You can force objects to remain on a surface in any number of ways, the simplest to use a get closest location on geometry and set new pointposition after your simulation node.
