Hi!
So I finally got it to work, a simple compound that 'glues' a mesh to a point cloud. To illustrate this, I've made a scene using Lagoa Jello to deform an artful model of mine ;)
I've attached the compound too if someone wants to experiment.
Claude
Glue Mesh To Point Cloud Compound
Glue Mesh To Point Cloud Compound that binds a mesh to a point cloud, suitable, for example, for jelly-like
deformations. Binds each mesh point to four point cloud points for a reference frame.
Useful in conjunction with Lagoa, but also with other types of point clouds like those
generated by voxelization compounds.
The difference to the built-in advect compounds is that it doesn't emit a point cloud
point at each mesh point and bind it - but looks for closest points in an existing
point cloud and binds to those. See this (V1.0) and this video (V2.0) for usage details.
local backup: GlueToPointCloudLocalCoord.xsicompound
claudevervoort
claudevervoort
Re: Glue Mesh To Point Cloud Compound
And now the improved version
I'm no more using a single point but rather a set of 4 points in the target point cloud, allowing for a more precise deformation therefore requiring less points in the Lagoa Simulation.
I also attach the revisited compound.
Claude
Claude
Cheers for sharing!
It's good to have an alternative to the "closed source" advect mesh compound.
iamVFX
Sweet, thanks!
claudevervoort
Thanks for looking at it!
rray, I don't think it is like Advect. When I looked at it, advect is creating a point per vertex and binding it. Those vertices would not therefore form a 3d grid and thus would not work very well in a simulation like the Jello. (In addition this compound can be used with any simulation, not just lagoa, although I have not found another example yet than the Jello
Claude
Claude
SamHowell
I love your compound! Thanks for the effort.
I see, thanks for the explanation.
Great compound & videos, too
*if you don't mind I'm going to use that last one as a thumbnail for Glue's entry at rray.de
Ray
Ray
milanvasek
great video Sam!!
SamHowell
Ha! Glad you like it. Thanks!milanvasek wrote:great video Sam!!
