Attached are a few compound that I updated and some.
They are:
Bezier3: A coumpound in the same line as the bezier4 factory compound
DB_Bezier3: A compound with tangent, normal and up vectors outputs
DB_Bezier4: the factory compound with tangent, normal and up vectors outputs
DB_RationalBezier3: a quadratic bezier compound with weighting on each control points
DB_RationalBezier4: a cubic bezier compound also with weighting on each control points
Enjoy. Let me know if you have a use for it.
Rational and enhanced Bezier Curves Compound
Rational and enhanced Bezier Curves Compound A set of compounds handling Bezier curves. Contains: Bezier3: A compound in the same line as the bezier4 factory compound DB_Bezier3: A compound with tangent, normal and up vectors outputs DB_Bezier4: the factory compound with tangent, normal and up vectors outputs DB_RationalBezier3: a quadratic bezier compound with weighting on each control point
local backup: DB_Bezier_Compounds.zip
author site: www.romanticdesigns.ca / si-community thread
Re: Bezier Curves Compound
More compounds
Pictures of the compounds
Interesting.
You may want to add one more download for convenience sake,
containing all the compounds for one easy download.
Something like this (I hope you don't mind...):
Re: Rational and enhanced Bezier Curves Compound
Thank Hirazi Blue for the compressed file, I don't mind at all.
