Implosia FX - new ICE based shatter
Mr.Core
Skype: giga-core
Post by Mr.Core » 03 Sep 2011, 17:19
Hi guys!
I have released first version of my experimental shatter on ice.
Check it here!
--Oleg
edit by owei: A local copy can be found here ( deprecated ): Implosia FX
The deprecated version (1.1) can be found locally here
Chris_TC
Re: Implosia FX - new ICE based shatter
Post by Chris_TC » 03 Sep 2011, 17:31
Awesome, thank you very much! :)
owei
Post by owei » 03 Sep 2011, 17:33
Hey Oleg!
Great news! Just send me a copy an we can host it in the download section if you like!
The address: info@si-community.com
best,
oliver
Mr.Core
Skype: giga-core
Post by Mr.Core » 03 Sep 2011, 17:38
Oliver
I sent a copy, thanks!
owei
Post by owei » 03 Sep 2011, 17:45
Thanks! I´ve upped it and added the link to your post ;)
best,
oliver
panjian46868
Post by panjian46868 » 04 Sep 2011, 02:34
Mr core
big thanks
that's why?
' WARNING : 3000-EDIT-AddICECompoundNode - Could not find node : IFX_Accessor
' WARNING : 3000-EDIT-AddICECompoundNode - Could not find node : IFX_Voronoi
' WARNING : 3000-EDIT-AddICECompoundNode - Could not find node : IFX_Continuous
' WARNING : 3000-EDIT-AddICECompoundNode - Could not set value on [SortArrayWithKeyNode 0].array.array_x
' WARNING : 3000-EDIT-AddICECompoundNode - Could not set value on [SortArrayWithKeyNode 0].array.array_y
' WARNING : 3000-EDIT-AddICECompoundNode - Could not set value on [SortArrayWithKeyNode 0].array.array_z
' WARNING : 3000-EDIT-AddICECompoundNode - Could not set value on [GetArraySubIndicesNode 1].array.array_x
' WARNING : 3000-EDIT-AddICECompoundNode - Could not set value on [GetArraySubIndicesNode 1].array.array_y
' WARNING : 3000-EDIT-AddICECompoundNode - Could not set value on [GetArraySubIndicesNode 1].array.array_z
' WARNING : 3000-EDIT-AddICECompoundNode - Could not set value on [PassThroughNode 2].in.in_x
' WARNING : 3000-EDIT-AddICECompoundNode - Could not set value on [PassThroughNode 2].in.in_y
' WARNING : 3000-EDIT-AddICECompoundNode - Could not set value on [PassThroughNode 2].in.in_z
' WARNING : 3000-EDIT-AddICECompoundNode - Could not find node : IFX_ICE_Boolean
' WARNING : 3000-EDIT-AddICECompoundNode - Could not set value on [Set Data 20].Value.Value_string
' WARNING : 3000-EDIT-AddICECompoundNode - Could not set value on [Set Data 20].Value.Value_uimode
' WARNING : 3000-EDIT-AddICECompoundNode - Could not set value on [Set Data 20].Value.Value_filepathseq
' WARNING : 3000-EDIT-AddICECompoundNode - Could not set value on [Set Data 20].Value.Value_filename
may be lost (IFX_Accessor、 IFX_Voronoi、 IFX_Continuous、IFX_ICE_Boolean ... ... ) ICE node
sorry my bad english
:-o
Mr.Core
Skype: giga-core
Post by Mr.Core » 04 Sep 2011, 08:50
Probably you need to install this
owei: PLEASE USE URL TAGS!!!!!!!!!!!!!!!!!!!! THANKS!
panjian46868
Post by panjian46868 » 04 Sep 2011, 09:33
Problem has been solved, thanks!
Firebird
Post by Firebird » 04 Sep 2011, 10:20
Amazing tool. And Thanks for sharing.
Was following it since the first video and was really impressed.
Have to give it a test.
Post by rray » 04 Sep 2011, 13:31
That's a very professional implemetaion, very nice! Will be fun to play with.
Post by Maximus » 04 Sep 2011, 14:00
This is truly a great work.. thanks for sharing, playing with it right now and it is really fast!
Great Job!!
Mr.Core
Skype: giga-core
Post by Mr.Core » 04 Sep 2011, 14:04
I am happy that you like it!
Thanks! :)
Leo
Post by Leo » 04 Sep 2011, 15:04
The limitation of ICEmodeling to the modeling stack makes it impossible to create any form of collisionbased shatters with this right?
Incredible work man. The speed and feature variety is just astounding!
Mr.Core
Skype: giga-core
Post by Mr.Core » 04 Sep 2011, 15:13
Leo
You are partially right. You can create a null-helper with sim-tree and process any calculations on points and then just put it to target polymesh.
I set the port's context on my nodes as per-object arrays, so you can try to build some dynamical shatter or something like it - there are no limitations exept ICE modeling stack and absence of RBD solver with the same port's context.
Leo
Post by Leo » 04 Sep 2011, 15:18
Mr.Core wrote:Leo
Interesting could you delve into a little more detail? Or is there maybe a sample scene I've overlooked?
Mr.Core
Skype: giga-core
Post by Mr.Core » 04 Sep 2011, 15:37
I will try to make simple scene to describe what did i meant.
Here is some disscussion about that
It is interesting task but currently I focused on implementation of image based cutting and iterative fragmentation like this Image
