quickinset
QuickInsetAuthor: Piotrek Marczak
Updated May 2013 (info) — Rewrite of the original QuickExtrude tool. This tool performs quick modo-like interactive extrude, bevel and inset operations without showing a property page. Piotrek's notes from the si-community thread: Extruding along normal is available only in 2012 SAP for operations that relies on SI units you drag in component's normal direction, for other ops (like point skirting ratio/bevel subdivisions) just drag across screen subdivision highlighting is supported only for level 1 and only catmull-clark J, L hotkeys change subdivision on extrude K hotkey is for repeating operation on highlighted component/subselection ENTER shows op PPG shift makes operations 10x slower LMB is extruding, LMB and then RMB - changes inset ratio of extrusion MMB is beveling, , MMB and then RMB - changes bevel subdivisions RMB is insetting tool can also work in supra mode if you hotkey the tool I've used it to model few production objects and it's pretty useful.
quickinset
Post by origin » 16 Aug 2011, 22:26
Tool was rewritten few times, so please report bugs...
- Extruding along normal is available only in 2012 SAP
- for operations that relies on SI units you drag in component's normal direction, for other ops (like point skirting ratio/bevel subdivisions) just drag across screen
- subdivision highlighting is supported only for level 1 and only catmull-clark
- J, L hotkeys change subdivision on extrude
- K hotkey is for repeating operation on highlighted component/subselection
- ENTER shows op PPG
- shift makes operations 10x slower
- LMB is extruding, LMB and then RMB - changes inset ratio of extrusion
- MMB is beveling, , MMB and then RMB - changes bevel subdivisions
- RMB is insetting
- tool can also work in supra mode if you hotkey the tool
- I've used it to model few production objects and it's pretty useful
Memag
Re: C++ custom tool SDK programming tip
Post by Memag » 16 Aug 2011, 22:36
WOW!!
That's what Softimage needs, interactive extrude and quick tools like your hybrid.
Oh, and I love poly highlighting!
Now if you could throw in edge bevel/extrude into same tool it would be killer.
Do you use modifiers, or just mouse buttons?
Please proceed.
Post by origin » 17 Aug 2011, 06:52
Right now I only use left/middle mouse button (repeat last extrude) and TAB to switch between extrude/inset mode.
bottleofram
Post by bottleofram » 17 Aug 2011, 07:10
That is indeed an impressive tool, Piotrek. The reason why i always liked silo (and im sure it applies to other well known modelers) is it combines as many operation into one tool as possible. Quite a fewer hotkeys would be needed if the modeling tools in xsi were designed this way...
Post by origin » 17 Aug 2011, 07:13
thanks, It is more a training tool to get familiar with c++ after 15 years of not using it. hopefully things will go faster now cause this tool took me 3 long days to get done.
Memag
Post by Memag » 17 Aug 2011, 07:23
That's great, it means you can make 100 tools per year!
Post by origin » 17 Aug 2011, 08:46
hehe, I wish ;)
Post by Hirazi Blue » 17 Aug 2011, 09:56
Looks great... :-bd
Is this more of a "proof of concept", an "inhouse tool" or do you plan to release it someday?
Re: quickinset
Post by origin » 17 Aug 2011, 10:41
mostly for learning, I plan to do more and will be sharing this as soon as possible.
Ramon
Re: quickinset
Post by Ramon » 17 Aug 2011, 11:54
gr8 origin!
Possible to show value numbers of insets and extrude?
Re: quickinset
Post by origin » 17 Aug 2011, 12:08
uploaded new video with point and edge working and spacebar as inset/skirting ratio mod while extruding
ramon: yes definitly
Memag
Re: quickinset
Post by Memag » 17 Aug 2011, 15:07
You are nailing it Piotrek! Really exciting stuff.
Love the purple highlight color. :ymblushing:
Will you release the code with the tools?
Thanks.
Re: quickinset
Post by rray » 17 Aug 2011, 16:41
cool tool :-bd B-)
I'm still undecided if I'd prefere a big number of new tools that do a small number of things, or vice-versa xD
Re: quickinset
Post by origin » 17 Aug 2011, 20:22
OK here's "release candidate", let me know if it's working for you, suggestions are welcome!
x64 only as .xsiaddon
menu modify->Quick Inset or run command pmQuickInset()
this help is displayed in status bar:
tab - switch between inset and extrude mode
hold SPACE when extruding to adjust inset (bevel)
hold SHIFT to do 0.1 increments when extruding/insetting
middle mouse button = repeat last op
enter - show last op PPG
Please do not learn from my c++ code... B-)
Zafar Iqbal
Re: quickinset
Post by Zafar Iqbal » 17 Aug 2011, 21:34
This looks great. Thanks!
- Zafar Iqbal
scaron
Re: quickinset
Post by scaron » 17 Aug 2011, 21:41
thanks for sharing the code, i hope it encourages more programmers/TDs to develop using the new sdk.
