keyvis QMenu 0.95 (SI2012 compatible)
New plugins, tools etc.
Post by Hirazi Blue » 05 Aug 2011, 20:16
An update to Qmenu has been released with SI2012 compatibility...
QMenu is a custom quad-menu system for Softimage similar to 3dsMax’s quad menu system.
Product page
Feature video: http://vimeo.com/27310721
Download it here
Re: keyvis QMenu 0.96
Post by Hirazi Blue » 12 Aug 2011, 11:02
(important) update: keyvis QMenu 0.96
# Version 0.96
# Code Changes:
# Added QMenu awareness of differently named Face Robot View Manager ("frmviewmanager" instead of the usual "vm").
# Query user to save config file when closing Softimage even when menu items were only added via ICE and Render Tree views.
# Graceful handling of likely Softimage bug that prevents getting the View Managers "viewportundermouse" Attribute Value in user (i.e. non-factory) Layouts. Now does nothing in v0.96, used to crashed v0.95)
# Fixed QMenu rendering on Multi-Monitor setups.
#Config file changes:
#Added "Null" Class object awareness to the "Any Object" Context
#Fixed Parameter editing menu items code so they also work with compound parameters that are not of the "Parameter" class (like scl, ori, pos )
arvinmoses
Re: keyvis QMenu 0.95 (SI2012 compatible)
Post by arvinmoses » 15 Sep 2011, 15:26
I just switched from xpop to this and love it so far!!!
I usually go with no ui flow when modeling, so this is great!
One request is could you try to/implement SI shortcuts in it. I.E. when you open SI menus letters are underlined. When you tap one of those letters the command will auto execute.
bottleofram
Post by bottleofram » 05 Mar 2012, 18:12
A small bug when using "OBJ Import..." command:
after conforming the chosen file, new window pops up in front of the the old one.
