Slice geometry with ICE
SreckoM
Skype: srecko.micic
Post by SreckoM » 03 Aug 2011, 18:02
I am using Slice node to slice geometry with another one, but I am facing problem when geometry that slice becomes concave.
Image will explain better.
http://screencast.com/t/nP6eZKpffMNo
http://screencast.com/t/aYz082v4RiPb
How to overcome this, any tips?
- H -
Tekano
Re: Slice geometry with ICE
Post by Tekano » 03 Aug 2011, 19:50
Oof! see what you mean, but what slice node? the slice polygon?
SreckoM
Skype: srecko.micic
Post by SreckoM » 03 Aug 2011, 19:58
Yeah, Slice polygon. Problem is that it creates infinite planes. Right now I am examining Guillaume 'Cut between two vertices' node to see how and if I can implement this. Still learning ICE and ...
- H -
SreckoM
Skype: srecko.micic
Post by SreckoM » 03 Aug 2011, 20:39
OK I found one possible solution, just to delete vertices that are outside of slicing geometry.
- H -
Tekano
Post by Tekano » 04 Aug 2011, 09:58
Yeah I couldnt figure out how you were defining the bounding polygon shape, it looked like you were slicing with some kind of Boolean - because the slice polygon node uses just an infinite plane (a vector point with a normal) and it shouldnt really care if the original geometry is concave or convex?
Im still learning ICE modelling too! :)
SreckoM
Skype: srecko.micic
Post by SreckoM » 04 Aug 2011, 10:31
- H -
