Spring Force Compound
Spring Force compound
Can be used to apply Spring Like behaviour - needs to have the Spring original positions
defined in a modelling stack onto a variable called 'orig_positions'
See download page for a comprehensive article on a use case of this compound (Simulating a field of flowers using strands).
local backup: Spring Force.xsicompound
author site: https://sites.google.com/site/tekanoice / download: ../tutorials/ice-flowers-part-i / si-community thread
Tekano
Can be used to apply Spring Like behaviour - needs to have the Spring original positions defined in a modelling stack onto a variable called 'orig_positions' see here for usage and details Tutorial using Spring Force with Strands
Memag
Re: Spring Force Compound
Hi Tekano, the links of both of your posts don't work.
Can you check it?
Thanks.
Can you check it?
Thanks.
Tekano
ah sorry about that I left an extra url] in there by mistake - hopefully they are working now? they seem to work my end. thanks!
