How to make a sphere?
Letterbox
No its not a joke.
The only catch is that each and every polygon must be of equal area.
Edit: No triangles, only quads. With the possible exception of the poles.
Terry
Terry
Diurno
Re: How to make a sphere?
i'm afraid i don't understard....
Letterbox
I cant explain it simpler...Diurno wrote:i'm afraid i don't understard....
a sphere... ok. No problem there, but if you make one, the polys are not equal in area, are they. No.
I was looking for a method to make a sphere where every poly in there sphere is the same area.
Terry
Diurno
you mean like the Geo Sphere of 3dmax? but it has all triangle...
druitre
well... make a cube and smooth the living daylights out of it?
Letterbox
Only problem with that is you'd only get 4 sidesdruitre wrote:well... make a cube and smooth the living daylights out of it?
Would like to have it a bit more user friendly in terms of upping the poly count
druitre
just up the divisions number (before the smooth op)
Letterbox
someone just emailed me that, but the problem is that the u & v dont lie on the circumference, like a "normal sphere". Which I didn't think of until i saw the image.Diurno wrote:you mean like the Geo Sphere of 3dmax? but it has all triangle...
Terry
PS Not so easy
Diurno
but in this way the poligons in the angles have a different size...
Letterbox
You still wouldn't get a TRUE sphere, you'd get the sides still would end up being flat compared to the corners.druitre wrote:just up the divisions number (before the smooth op)
druitre
Ah yes, you're right, and you'd still have irregular geometry.
druitre
What about this one: create icosahedron, local subdivision refinement (catmull clarke) x 1. All quads, looks like.
[edit:] Have to admit that that's the highest count all-quad equal area sphere i can get... this is harder than I thought
Letterbox
That's close, but you dont have the U & V around the circumference.druitre wrote:What about this one: create icosahedron, local subdivision refinement (catmull clarke) x 1. All quads, looks like.
This is a ridiculous question it sounds so simple. He just says he wanted a sphere, make up of equal rectangles (quads), and the isolines to be around the circumference. so he can animate each square. With the exception of the poles.
It doesn't sound that hard does it.. I tell you if it can be done I sure dont know how.
Now I think I know why Transformers picked a CUBE...
Diurno
what does it mean "U & V around the circumference" ?Letterbox wrote:That's close, but you dont have the U & V around the circumference.druitre wrote:What about this one: create icosahedron, local subdivision refinement (catmull clarke) x 1. All quads, looks like.
Letterbox
Like if you make an ordinary sphere, you have a loop around both horizontal & vertical that go around the sphere. = U & V around the circumference = smooth curve around the sphere.Diurno wrote:what does it mean "U & V around the circumference" ?Letterbox wrote:That's close, but you dont have the U & V around the circumference.druitre wrote:What about this one: create icosahedron, local subdivision refinement (catmull clarke) x 1. All quads, looks like.
Letterbox
I'd thought I post this as its a solution i found on the web.
http://www.maths.anu.edu.au/~leopardi/V ... slides.pdf
