Uv mapping per face
UV Mapping Per FaceAuthor: Softimage
This script maps the whole UV(0,0)-(1,1) space to each polygon (works best with four-sided polygons). Select a polygon mesh object, then run the script. A documentation sample converted by Piotrek Marczak.
local backup: ooSetPerFaceUV.pys
SreckoM
Skype: srecko.micic
Uv mapping per face
Post by SreckoM » 18 Jul 2011, 19:32
I am sure that title is greatly misleading so here it is again. I need somehow to UV map geometry so every face of it occupies 0-1 range of UV space. It will lead to overlapping but that is something I need.
Option that does this in Modo is called Barycentric, if this can help to explain better what am trying to achieve.
Is this achievable in XSI?
- H -
Re: Uv mapping per face
Post by origin » 18 Jul 2011, 21:44
try this script
(translation of doc's vbscript to python)
http://dl.dropbox.com/u/8079325/ooSetPerFaceUV.pys
SreckoM
Skype: srecko.micic
Post by SreckoM » 19 Jul 2011, 11:38
Thank you!
- H -
Post by origin » 21 Jul 2011, 08:15
Ive updated the script because CurrentUVs sometimes failed
iamVFX
Post by iamVFX » 15 Sep 2011, 20:42
#tuple to list - wtf...
꞉D
Great script, thanks!
