UV samples to polygon selection?
gaboraa
Post by gaboraa » 18 Jul 2011, 07:44
Hi all,
Maybe this is a noobish question of the week but things doesn't simple at times:)
As title says how can I convert UV samples to polygon selection? When I select the UV samples in the UV editor, I cannot convert them to polygon selection.
Re: UV samples to polygon selection?
Post by Hirazi Blue » 18 Jul 2011, 07:49
Not 100% sure, but I think this might be the answer...
In the Texture Editor Preferences:
Turn on "Auto Sync" and set "Sync Method" to "Components" ;)
gaboraa
Post by gaboraa » 18 Jul 2011, 07:53
Yes, that's it! Thank you so much :ymapplause:
Ramon
Post by Ramon » 18 Jul 2011, 15:13
can we do edge loop selection in texture editor?
gaboraa
Post by gaboraa » 18 Jul 2011, 15:42
As far as I know, no but you always can select your edge loop with standard tools and it will be automatically reflected in the texture editor.
