Rot limit and IK
McNistor
Rot limit and IK
Is there a way to impose rotation limit on local Z axis of the 2nd bone in a normal limb (2 boned arm/leg) when animating in IK? For FK this is very straight forward on the kinematics ppg of the bone, but what about IK? Putting a rot limit doesn't help when you're doing IK so what do you think, should I investigate this in ICE or do you know a traditional method?
-Thucydides
-Thucydides
Re: Rot limit and IK
in 'traditional' way, you create a new layer of nulls with same hierarchy, link them to IK chain, create conditional expression - or some creativity with direction constraint (if you 'swap' up-vector and target, you'll get 'one axis constrained rotation'). Something along this line....
In ICE kinematics, probably you'll do the same, but instead nulls, you're using nodes, get-set data...
Anyway, anything complex won't go without 'layering'. Let's say, you can't drive parent's transform by child's transform, but you can drive both parent and child in opposite directions, using some external controller.
McNistor
Can you elaborate on that a little please? What target and what do you mean by "swap"?Mathaeus wrote:if you 'swap' up-vector and target, you'll get 'one axis constrained rotation
-Thucydides
-Thucydides
you can just try this, create cube, create direction constrain to null, use another null as an up-vector. Move nulls, and you'll notice the difference.
hopefully a famous Isner's page about rotations is still alive.
Setting rotation limits on the 2nd bone works for me.
McNistor
you must have a different XSIEricTRocks wrote:Setting rotation limits on the 2nd bone works for me.
that or you didn't read this thread carefully
edit: OR I'm stupid as it turns out if you continue reading below
-Thucydides
-Thucydides
SI 2010 SP1McNistor wrote:you must have a different XSIEricTRocks wrote:Setting rotation limits on the 2nd bone works for me.
Run this, grab the effector and have a whirl.
# Python
Application.NewScene()
Application.ActivateObjectSelTool("")
Application.Create2DSkeleton(-6.25118771807394E-02, 0, -5.00348380103928E-02, 6.18867584089323, 0, -6.32940700823774, -90, 45.1288727277488, 0, 4, "", "")
Application.AppendBone("eff", 13.3900440921144, 0, -7.50522570152823E-02, "")
Application.SelectObj("bone,bone1", "", True)
Application.SelectObj("bone1", "", True)
Application.SetValue("bone1.joint.rotlim_active", True, "")
Application.SetValue("Views.ViewA.TopCamera.camvis.attrselchnjntareaguide", True, "")
Application.SetValue("Views.ViewA.TopCamera.camvis.attrunselchnjntareaguide", True, "")
Application.SetValue("bone1.joint.rotmaxz", -60, "")
Application.SelectObj("eff", "", True)
Application.Translate("", 8.27209190550114, 4.69911679517001, 0, "siRelative", "siLocal", "siObj", "siXYZ", "", "", "", "", "", "", "", "", "", 0, "")
McNistor
I know about rotations man, but thanks for the info anyway.Mathaeus wrote:you can just try this, create cube, create direction constrain to null, use another null as an up-vector. Move nulls, and you'll notice the difference.
I'm not sure that you understood exactly what my question was seeing your setup with cube and nulls. Or maybe you did understand and it is somehow related and I just don't see how?
-Thucydides
-Thucydides
McNistor
Alright EricTRocks, that works.
I need the limit to act when the bones come closer to each other not when they're spreading apart. What should I modify?
I know nothing of Python but I have some C and C++ training so O'll play wiht it maybe I'll figure it out. But you do tell in the meantime please
p.s. Hmmm, some interesting stuff on your website man, very very nice!
edit: ok, the -60 value seems to do the trick
another edit: it seems that this can be achieved without scripting, straight through XSI's interface. Should I've known that, I wouldn't had opened this thread. Anyway, it's good for posterity.
-Thucydides
-Thucydides
I just gave you a script that reproduced the changes I made in my scene. Select the 2nd bone and hit enter to bring up its Property Page. Look for the "Rotation Limits" tab. There you can adjust those limits on the bone. Change the min/max to suit your needs. Also you should enable the visibility of the joint rotation limits in the viewport options to help you see them while you're editing them.
McNistor
Yes, yes, I've figured it out by nowEricTRocks wrote:I just gave you a script that reproduced the changes I made in my scene. Select the 2nd bone and hit enter to bring up its Property Page. Look for the "Rotation Limits" tab. There you can adjust those limits on the bone. Change the min/max to suit your needs. Also you should enable the visibility of the joint rotation limits in the viewport options to help you see them while you're editing them.
Thanks man.
The problem is that I was using the rot limits kinematics ppg (ctrl+K), forgetting that bones are special objects that dance on their own music.
-Thucydides
-Thucydides
well I'm a lazy to go with full exampleMcNistor wrote:Mathaeus wrote: I'm not sure that you understood exactly what my question was seeing your setup with cube and nulls. Or maybe you did understand and it is somehow related and I just don't see how?
afaik, small problem with limits in IK chain PPG is, that they can go in conflict with (possible) additional constraints. If you apply an additional constraint, which forces rotation into 'restricted' zone, IK chain become blocked.
McNistor
Please explain.
Most probably I'll use lots of controls and constraints as the limb I'll have to rig is a spider leg with six bones - 2x3 or 3x2 chains. Btw, do you think it's better to have 2 chains with 3 bones or 3 with 2? Or maybe only one 6 bones chain?
-Thucydides
-Thucydides
well, all I can say here, is that I've learned to live without rotations limits in IK chain PPG, sometimes around XSI 4 or 5. Just that. Constraints should be fine.McNistor wrote:Please explain.
2 with 3, 3 with 2... 2 bone chain, by it's nature, requires a simple, 'definitive' math. There is only one result. 3 bones or more, requires additional parameters ( preferred angle), result is arbitrary. I'd say, if you can use 2 bone chain, go for it.
