Hello!
I'm trying to recreate expression in ICE to offset, i.e. position from one object into another (spring effect). I've come across an obstacle while trying to figure out a way to create a frame offset in ICE. The only thing i can get is to get "one frame" offset by using get data and get data from previous frame, but i need to be able to define how many frames i want the offset to be. Is that possible without getting into deeper "math-node" building?
ICE Frame Offset
Chris_TC
Re: ICE Frame Offset
Could you store a position array? Every array index would contain the value of that frame (index 0 = position at frame 0, index 1 = position at frame 1....).
Gith
thanks for the hint!
