The book is a series of image, with a little (too little IMO) comment below. The tutorials (three in total, one generic and touch many XSI parts (a mantis) and other more specifics).
In Mantis tutorial I find a problem in rendering section. Author create a override for the material, in one partition. In this override he had only the Material_Material parameter, selected from base material properties. After this, in render tree, he add a SSS Fast Skin and connect to override node. Now, in Softimage 2011 (and I controlled 2012 and is the some) there is no more this material, but a Find the Fast Skin (misss). The problem is I cannot connect Fast Skin (misss) node with Override node. I tried many time, adding different parameters to my override node (all parameters), but no one match with Fast Skin (misss) output, this node a different output color (brown) and cannot connect with any input in my override node. The strange thing is I can connect Fast Skin (misss) with a normal material node, he connect to MATERIAL input, but if I override material input parameter don't work ( had a different name MATERIAL-MATERIAL and different colour ( a dark brown).
Any help about?
