I don't get any results which work in a way I'd expect them to work. Is this "feature" broken? I just wanted to come up with a small test. Cylinder deforms high res cylinder, but the high res points are just popping in the wrong direction. Do I miss something?
One ICE tree in the modeling section, one above. That should do, or?
Pancho
Hull deformation
Pancho
Hull deformation
grahamef
Re: Hull deformation
You need to use two versions of the low-res geo: one to define the "rest" shape, and one that you manipulate.
http://download.autodesk.com/global/doc ... d28e297337
Pancho
Probably I should go back to school and refresh my English. Then I might be able to read properly.
Thanks very much!!!
Thanks very much!!!
