Attached is an ICE compound that flips an object over 180degrees, duplicates it and flips again.
Create an empty point cloud with a simulated ICE tree and plug this compound on. It creates 1 point itself to start with, so no need to emit anything yourself.
Create a cube, which the compound will automatically pick up on the name. ie 'cube'. Make the cube size 1 and move its centre to 0.5,0,0. This just means the cube will flip around its right hand edge.
Any problems, just post here!
Chris
Direct download can be found here:
http://www.si-community.com/download/co ... _right.zip
cm_flip_right by Chris Marshall
owei
ChrisMarshall
Re: cm_flip_right by Chris Marshall
If anyone's playing with this, to modify the speed of the flipping object, adjust the value in the Add node, if that isn't too obvious. I guess I could have exposed that number.
The whole compound isn't very flexible as it's very much been designed to just perform the one task. I've modified it for some of the examples on Vimeo, so it flips in all directions, so it's fairly straight forward to tweak.
Chris
Chris
Matic
Hey thanks for sharing it Chris!
ChrisMarshall
No problem. Just wondering if anyone managed to get this working in some shape?
lorax
hey chris..
first of all.. thanks for sharing this. as i am new to xsi and i wanted to play around with ICE a bit it would be very helpful if you could upload a picture of your ICE tree and how which plugs into what.. that would be awesome!
thanks man!
thanks man!
lorax
hey folks..
this doesnt seem to work for me.. i must be doing something wrong.. heres what i did:
i opened a new scene. then i created an empty point cloud via Primitive>PointCloud>Empty
i opened the ICE Tree and did Create>ICE Tree
then i imported the compound and plugged into port1 on my ICE Tree.
i made a cube with the size 1 and relocated it as chris mentioned (0.5 , 0, 0)
now when i try to play my animation nothing happens.. what did i do wrong?
it would be awesome if someone could point it out to me.. thanks!
lorax
by the way.. is that a face of a woman in the video? how did you manage to do that?
lorax
got it workin.. thanks man! nice setup!
lorax
what would be very helpful is to know how you went about tweaking this setup to get the output shown on the video up there. i can't quite grasp how you got it to spread the way it does..
i'm currently workin on a little project where this setup could come in quite handy.. could you please explain some more or maybe just post a pic of the ICE tree you used in the generation of this video?
peace.keep the good stuff flowin!
3DMagic
- Skype: emiliano.grimaldi
I will also be interested in viewing the final setup. Very nice effect!
