Iray
virtuald
Iray
Post by virtuald » 04 Jun 2011, 10:00
I have installed ctrl_ghost, and iray in render region works fine. If I set (for example) 500 max samples render work exactly with 500 samples, but if I launch render manager, rendering always stop at 100 samples.
Please help.
Re: Iray
Post by Rork » 05 Jun 2011, 08:47
render region settings are separate from the ones in the manager, is that maybe the case?
Just check that box in the renderregion options to look at the rendermanager for settings to see if that helps.
If not, maybe there's a settings in the plugin? Haven't tried it yet, so dunno.....
