OpenGL Mix8colors Available
New plugins, tools etc.
Memag
Post by Memag » 25 May 2011, 10:45
Chucky made this awesome shader available...
This is a realtime Mix8colors with a vertex color lookup. With this realtime shader you can :
- Mix several textures.
- Paint the influence of your textures in realtime.
- Visualize several weightmaps.
- Use the vertexcolors as clusters.
There are 2 versions of the shader, I recommend you use OpenGL Mix4colors if you don't need to display 8 textures. The 8 layers version is in beta and there's a bug : if you load a scene with OpenGL Mix8colors connected, the viewport will be slow and you'll need to refresh the shader to make it fast again. OpenGL Mix4colors doesn't have this bug.
DOWNLOAD
xsibase thread
Chucky's Demo
clementmallard@gmail.com
McNistor
Re: OpenGL Mix8colors Available
Post by McNistor » 28 May 2011, 01:46
Awesome! What is it?
-Thucydides
