I have tried all sorts of combinations to make this node work, but it just won't. It's so annoying. Here's the deal:
I have modeled a tube and want to cap both ends. I want the cap to consist of several triangular polygons, the same way cylinder caps are created in Get->Primitive-Cylinder
To do this, I'm trying to add a "floating vertex" in the center of where the cap will later be. But when I try to use Add Polygon, nothing happens. And the vertex added with Add Vertex never shows up in the viewport either.
The manual specifically says that floating vertices are deleted after an ICE tree is evaluated, and that they should be connected. But it never works. Try adding three vertices to an empty polymesh with Add Vertex, and then using Add Polygon to draw a polygon. Nothing happens. What am I doing wrong?
ICE modeling - Add Vertex node does not work?
Re: ICE modeling - Add Vertex node does not work?
This is what I did:
Chris_TC
I'm confused. This is exactly what I had been doing. I just tried it again, and now it worked flawlessly.
So obviously I must have been doing it differently. But I'm certain I wasn't. Oh, whatever, thank you for helping!
Chris_TC
I don't really want to start a new topic for this. It's probably just more stupidity of mine.
But how do I convert polygon indices to polygon positions? My object has an integer array of polygon indices. Now I want to turn these into a vector array of polygon positions. None of the conversions I tried have worked
This is the first thing that came to mind. PolygonsInsideNull is an array of polygon indices...
Chris_TC
Once again you saved the day. The solution is sooooo simple, but I could not think of it. Thank you very much!
