Help please!
I noticed that my geometry was not symmetric so I deleted 1 side then I Symmetrized and Merged, then I used gator to transfer my uvs from the old mesh (the none symmetric mesh) and this is what I get
UV transfer via gator is unreliable. It does what you see there and often weld or heals points that you didn't want healed. If you are cutting your model in half and re mirroring I would recommend that you duplicate and scale -1 instead of symmetrizing the model to get the 2 sides then merge them and keep the uv's in tact. After that select the mirrored half and flip those UV's in the editor and re heal the center seams as needed.
Clean up the excess clusters and stuff as needed also.
