overriding scene ambience per pass
eternal art
Post by eternal art » 13 Jul 2009, 22:41
Hi there
Just wondering if anyone knows how to override the scene ambience on a per pass basis ??
there are a solution but it's not a a faster one
http://www.xsibase.com/forum/index.php? ... adid=33625
If anyone knows of an easier/faster way to do it, I'd like to hear about it.
clyder
Re: overriding scene ambience per pass
Post by clyder » 18 Jul 2009, 08:04
Create an implicit object.
Add a custom parameter set onto it.
On this cpset, add 4 parameters: red, green, blue, alpha.
Link via expressions the scene ambience with the cpset parameters. To do that, switch the Explorer to local properties, and set the scope to All Nodes. Expand the AmbientLighting node you'll see under the scene root. Open the cpset, and drag-n-drop its parameters onto those of the AmbientLighting object.
On each pass, create a partition that contains only the implicit object.
On this partition, add an override.
To this override, add 4 parameters that override the cpset parameters.
This is very nice solution that dont require lot of time to do. Instead of custom parameter set with 4 parameters you could give that control object a CustomColor property and link red/green/blue values of ambience to RGB values of customColor property. That way the process would be slightly faster.
owei
Post by owei » 20 Jul 2009, 10:22
Hi..!
I´ve build a small addon to close this cab...Thanks Eric for help ;)
This addon adds an "Ambience"-property to the selected pass.
Usage:
- select the pass you wish to add this property
- Get>Property>Ambience
- repeat this for every pass of your scene
..now you should be able to set a specific ambient lightning color to each pass...values are updated for every value-change on the PPG and on every pass change
Hope it works the way it should..please test it..! If not, post here...hope you like it ;-)
cheers,
oliver
eternal art
Post by eternal art » 20 Jul 2009, 12:30
thanks you very much owei ... i will test it as soon as possible .
