I have this piece of ICE tree that need to repeat based on an integer value input. It repeat between the add node and the scalar to vector node, with each iteration feeding a value to an array. In code that would be easy:
var u = 4;
var x = -.05;
for (i=1, i <= u-1, i++) {
x = x + 1/u ;
Thank you for your help!
