Anyone experienced absurdly huge fgmap files when caching fg to disk?
I just tried to render a scene with fg points from disk, and softimage froze, then crashed. I checked and found my fgmap file was over 6Gig in size for 38 HD frames. Settings: expert, 150 samples min 0,01, max 0,5. Scene has about 800 Polys.
I lowered the settings to 150/0,1/1 and now I have about 80 megs per frame for the fgmap file.
Also it seems, that when "append " is active, mr uses only one core!
can anyone confirm this?
Achim
Edit: I just found, that with every frame the fgmap size doubles!
huge fgmap files
Lord Futzi Voldemort
huge fgmap files
Re: huge fgmap files
my last fgmap was 3.56 gb for a 800.000 polygon scene. there is something wrong indeed.
viewtopic.php?f=36&t=1380&start=90
Moderator edit:
You linked to a "reply" page, I tried to correct this, am however not sure which page of the thread you meant to point to - HB
@Hirazi, yeah sorry i failed the link, thanks for the fix
Moderator edit:
I talked to support who confirmed this issue and logged it as a bug.
Achim
Achim
