How to add modeling compound to modeling menu?
Just wondering if anyone knows how to take a ICE modeling compound and add it to the main modeling menu such as under Modeling > Modify > Poly. Mesh and even better, under the context sensitive menus so you could use it just like a normal modeling tool?
Re: How to add modeling compound to modeling menu?
check it out
http://vimeo.com/18784546
in the last part he puts the modifer in the UI, if is what you wanna know
easy way: icetree->user tools->add operator to menu
hard way:
file->plugins->new command
pick menu you want
inject this code into execute part of generated script
save, done
hard way:
pick menu you want
ICEopName = "Your compound name"
ICEopNameUn=ICEopName.replace(/\s|\,/g,"_"); //replace spaces with underscore
sel = selection
for (i=0; i<sel.count;i++)
op = ApplyOp("ICETree", sel(i), siNode, null, null, 0);
AddICECompoundNode(ICEopName, op(0).Fullname);
ConnectICENodes(op(0).Fullname+".port1", op(0).Fullname+"."+ICEopNameUn+".Execute");
gaboraa
Great! This is what I want to know. I am going to test this soon
Thanks.
Thanks.
Ramon
create compound, export in user dir in compounds, add operator to menu, apply this operator to new object and error
ApplyICEOp "1234", , , siUnspecified
' ERROR : 21000-EDIT-PrivateGetCompoundConstructionMode - Unspecified failure - [line 712 in C:\Program Files\Autodesk\Softimage 2012 SP1\Application\DSScripts\operators.vbs]
construction_mode = PrivateGetCompoundConstructionMode( in_FilePath )
Ramon
ApplyICEOp "CaM5", , , siUnspecified
' ERROR : 21000-EDIT-PrivateGetCompoundConstructionMode - Unspecified failure - [line 720 in c:\Program Files\Autodesk\Softimage 2012.SAP\Application\DSScripts\operators.vbs]
