As you might allready know there are some compounds included with Softimage 2012 for shattering through ICE.
The problem with them is, that the shattering only works on concav meshes, so at the end it is quite useless.
Is there someone out there who is able to write a compound for shattering concav and convex meshes ?
Shattering in ICE ?
Helli
Re: Shattering in ICE ?
Helge tried this allready once and sadly he also had problems with convex meshes.
It's not easy to build a booleanlike solution.
At the end kratos is using the xsi booleans, which is why it is quite unstable.
