Rendering color and alpha particles...
gfxman
Post by gfxman » 28 Mar 2011, 16:39
Hi Guys,
maybe this is a really stupid question, but i'm a total noob to ice.
I want to drive the alpha of the particle.
I got it to work using the modify particle color: i'm using the "age limit" do drive the start of the fading effect.
In the openGL, it works as expected; but i'm struggling to render it.
What is the render tree set up, to get the color attribute to drive correctly both color and transparency of each particle?
I want to render with a phong node, avoiding the "particle volume render".
I tried to "pick" the alpha channel and put in the transparency node, but all turned green...
I'm stuck at a stupid thing, i know... but please help me!
Re: Rendering color and alpha particles...
Post by Hirazi Blue » 28 Mar 2011, 17:59
Not sure, but: Plug the "Attribute_Color" (RGBA, plugged together in the ICE tree) shader (also) in the Transparency port of your Phong shader and make sure to check the "Use Alpha" checkbox in the Transparency settings. ;)
gfxman
Post by gfxman » 29 Mar 2011, 09:33
Hirazi Blue wrote:Not sure, but: Plug the "Attribute_Color" (RGBA, plugged together in the ICE tree) shader (also) in the Transparency port of your Phong shader and make sure to check the "Use Alpha" checkbox in the Transparency settings. ;)
Thx for the reply.
That doesn't work when the particle type is set to "point"....
nautilus
Post by nautilus » 03 Apr 2011, 21:48
did you try the "rpc"-addon (render point cloud)?
just a thought
