Not quite sure how the syntax needs to be. I have a curve and I managed to get all point positions by the upper ice graph. Several points from this curve have been tied together as a cluster. So, how do I just get their positions and filter the points out which aren't part of the cluster?
Thanks in advance
Pancho
Small cluster/filter problem
Pancho
Re: Small cluster/filter problem
It probably depends on context but how about this?
Pancho
Thanks very much! Did take a while till I fully understood what's going on as I initally got only the non clustered point. A bit confusing. Then I realized that I need to check the value box in the "find in array" compound. Never used this one before. Now it works fine!
