Hey all, I was wondering if it's possible to re-assign mouse button functions in XSI, based on active window.
It's a small thing, but I was hoping to re-assign a middle click+drag to Pan around for tree views (Schematic, Render Tree, FXTree, & ICE Tree)
I have no clue where to start.. Any ideas?
(also eventually looking for a way to have the ` key mapped to clear+set cursor into the filter by name box for nodes)
Active window based mouse mapping
Re: Active window based mouse mapping
I'm not sure, but I don't think you're able to remap the mouse buttons in that way.
As to you second question: you can easily create a script command that does what you want and then you use a shortcut key to start that custom script command.
Agreed, probably not possible within Softimage - an option might be autohotkey (http://www.autohotkey.com/).
Takes some time to get used to, but very much worth the effort - I'm using it all the time for things like closing windows by mid-clicking the title bar, using the mouse wheel to scroll whatever is under the mouse (without having to activate it first)
