I purchased Messiah Studio Pro for 40 bucks. Good deal, I thought. I opened up the T Rex demo scene and tried to record a preview AVI file. Guess what happened? My RAM usage skyrocketed my computer -> since I tried it on a 32 bit machine with only 2 GB RAM -> had to use the hard drive as a scratchdisk and if I opened up the Windows Task manager it stopped recording the preview.
Softimage is much better at generating a preview and opening it in flipbook. MY advice -> DON'T WASTE YOUR MONEY ON THIS BUGGY PIECE OF SOFTWARE. IT'S NOT WORTH IT.
SOFTIMAGE ROCKS ;)
Comments?
Messiah Studio for 40 bucks don't fall for it.
jamination
Re: Messiah Studio for 40 bucks don't fall for it.
Little harsh for first impressions. I'd say you'd have to give it a bit more time before you could give it a fair review.
Phil Harbath
Jamination Productions
Yep
messiah is a good product not perfect but a lot things was made with it. If you have pb with it just go to the setuptab forum the community is very good.
--> http://setuptab.com/
Phil
Phil
wild guess, you picked avi without compression and it tried to fit all frames to memory...
For me it's still too early to tell as I haven't spent nearly enough time with Messiah to come to a well-founded conclusion, but I'd say: spending a mere 40 bucks on other software to unequivocally reaffirm your love for Softimage is not a bad investment either...
dirtydog
A problem I've found is smoothing you model requires a metanurbs operator( tab key), but doesn't allow tris or ngons, you then have the tedious task of remodelling or quadrangulate and subdivide before export. i'am new to messiah maybe someone knows better.
Knowing full-well this topic is slightly out of place in this Softimage minded community, I can't resist:
According to Messiah's online help the problem only should occur with N-gons, while triangles should be fine...
At least that's how I read the following:
But this is merely from looking at the manual, I obviously can't guarantee that Messiah has read its own manual and acts accordingly...Objects must not have polygons with more than 4 points in order to be MetaNURBS-capable.
dirtydog
Sorry it is only ngons, the model I used had a ngon that i never picked up.
