Getting point positions from other meshes?
j3st3r
Post by j3st3r » 28 Feb 2011, 20:22
Hey,
I'm going to make a compound, and I want to access the same point from another mesh. The mesh's topology is identical, but the second mesh is modified (shape target). So basically, if I am working with point 1 from meshA, I want to access point 1 on meshB.
Is it possible?
Thanks in advance!
Szabolcs
grahamef
Re: Getting point positions from other meshes?
Post by grahamef » 28 Feb 2011, 20:33
The Switch Context node is designed to do exactly that.
j3st3r
Post by j3st3r » 01 Mar 2011, 10:21
I tried it but it looks like that it doesn't help me too much. I want to get an average of the neighboring point positions of the same point of the other mesh...It looks like that when I switch context, the values are totally different. Checked with the show value before and after the Switch Context node...
I'll keep trying....
nakhato
Skype: nakhato@hotmail.com
Post by nakhato » 01 Mar 2011, 12:41
Hi there maybe this will help you
http://vimeo.com/11079196
j3st3r
Post by j3st3r » 02 Mar 2011, 09:32
Thanks, I checked, but when I try to use the self.ID, the node turns red and the message is that attribut ID is not initialized on blabla...
Post by origin » 02 Mar 2011, 10:16
Maybe this will help? Basically, PItL references every point of 'shape' mesh to current mesh, so you have Location on Shape mesh per point of original mesh, therefore you can pull out every data from shape mesh, like point position or point neighbours location.
Ive multiplied it by kine.global matrix in case of shape mesh have been translated.
j3st3r
Post by j3st3r » 02 Mar 2011, 10:50
Thanks you helped me a lot!
Next question, how can I get the current point positions? I mean, the one that is deformed by ICE tree...
I made a tree, that smooth a mesh in a special way, interactively, but I need to reuse the actual positions, not the original ones...any idea?
Post by origin » 03 Mar 2011, 11:00
I'm not sure what you're after, maybe screenshot would help. You can get modified positions after you Set point position. Or you can store your modifications in custom array (set data) and set points pos. on very end.
