Extruding different faces long his normal
Nizar
Post by Nizar » 25 Feb 2011, 01:13
Hope can you understood:
A friend of mine request me an help for an architectural modelling. He use modo for his works. One nice tool in modo is Bevel. It is different from SI Bevel, it is a combination of our bevel and our inset polygons tools.
Ok, my issue is about Inset polygons tool: Modo Bevel extrude polygons long his normal, instead Inset polygons tool extrude regards global coordinate. If I have a regular polygons mesh (like a square), I can extrude my polygons, then use scale tool on LOCAL coordinate, but if the polygons are, i. e., in a irregular room (with an "L" shape), this trick don't work properly.
Any idea about?
Nizar
Re: Extruding different faces long his normal
Post by Nizar » 25 Feb 2011, 12:28
Ok, I find the right tool for this work :) Push tool.
Post by Maximus » 25 Feb 2011, 12:59
can use this
http://www.xsibase.com/forum/index.php? ... 78;start=0
be sure to Freeze all transformation before you use it, if you getting weird results.
Nizar
Post by Nizar » 25 Feb 2011, 13:35
What is the difference between this and Push tool?
(fa un po' strano dover parlare con un altro italiano in iglese, ma visto che il forum è inglese... :)
gaboraa
Post by gaboraa » 18 May 2011, 20:30
Sometimes Push does not work but Move Normals always works for me.
