Hi! I am Caveman and I love Softimage. This is my first post in this forum and I hope to get some support from veteran Softimage users. Thanks.
Of to the topic now. Since the misss_physical_Phen and the misss_physical in Softimage 2011.5 and 2011, were buggy and I was getting this ugly result (Image with a glass) I had to resort to Physical_sss_mod from rray.de.
Now, I am not sure if Physical_sss_mod is causing this error but whenever I use the misss_fast shader I get this error
"' WARNING : 3000 - C:\Program Files\Autodesk\Softimage 2011 Subscription Advantage Pack\Application\phenolib\mi\subsurface.mi: Missing parameter or type mismatch applying 'Connection "lm_sample::diffuse_curve" = interface "a.diffuse_curve"'. Ignoring connection."
Accept for the error the fast shader is working properly. I would like to know if this is the correct way to setup the fast shader. I have attached the screenshot of the Rendertree setup.
Hope someone sees the post
misss_physical BUG
Caveman
misss_physical BUG
Re: misss_physical BUG
Can't reproduce here - does the warning still appear with the subsurface_2010 dll deleted?
Might be one of the cases where runonce.bat (see this link) could help.
I hope for an update of these shaders... the "fast" shaders sometimes have errors too (black spots) with raytracing mode.
Caveman
Hi! Thanks for replying. I have found that the error is shown only in that scene. I created another fast shader in a different scene and there was no error.rray wrote:Can't reproduce here - does the warning still appear with the subsurface_2010 dll deleted?
