Simulated ICE tree on an already deforming mesh.
SamHowell
Post by SamHowell » 11 Feb 2011, 18:51
Hello
I have some character animation upon which I would like to add some secondary animation using a simulated ICE tree. The only trouble with this is that as soon as I apply the simulated ICE tree the original mesh deform animation stops working.
Is it possible to have a simulated ICE tree on a deforming mesh? It Seems like it should be quite easy but for the life of me I can't get it to work.
Any tips would be a great help.
Sam
Re: Simulated ICE tree on an already deforming mesh.
Post by xsisupport » 11 Feb 2011, 21:42
Anything below the Simulation region is evaluated just once, to define the initial state of the simulation.
"By default, the initial state of a simulation is the result of the regions below the Simulation region on the first frame that the simulation environment is active. While the simulation is active, the lower regions are not re-evaluated. "
// Steve Blair
Pooby
Post by Pooby » 11 Feb 2011, 23:29
Use 2 identical meshes. One to pass the deformation across to the sim
SamHowell
Post by SamHowell » 12 Feb 2011, 19:50
OK, thanks for the tips.
So I need an identical second mesh with an extra sim for deforming the mesh according to the original.
Time for a mooch around the nodes.....
