Weight Map Trail?
SamHowell
Weight Map Trail?
Post by SamHowell » 11 Feb 2011, 15:54
Hello
Is it possible to generate a weightmap trail from the intersection of two mesh objects?
The Advanced Proximity Map compound does this but it updates every frame. I am hoping to find a way of having a weightmap build up over time as two objects move through each other.
I hope this makes sense. Any advice would be greatly appreciated.
Sam
grahamef
Re: Weight Map Trail?
Post by grahamef » 11 Feb 2011, 17:13
Permanent trail? Or do you want it to gradually die off? Either way, you'll need to use a simulated tree so that you can use values set by the previous frame.
For a gradual die-off, get the weight values, multiply by a value between 0 and 1 depending on how fast you want the effect to subside, then add a value for this frame.
For a permanent trail, just keep adding to the weight values. You'll eventually hit the weight map's max and it will be clamped.
SamHowell
Post by SamHowell » 11 Feb 2011, 17:43
Thanks for the tips.
I was hoping for a permamemt trail.
So I need to add weight values per frame on a simulated cloud? I thought I was already doing that, I shall have to take another look...
SamHowell
Post by SamHowell » 11 Feb 2011, 18:10
Is a Get Data At Previous Frame node a good way to go with this?
SamHowell
Post by SamHowell » 11 Feb 2011, 18:15
Oh, I've got it. Use .AddWeight in the set data.
At last. Thanks for your help.
