Hello, I'm searching a way to set the ice spheres resolution, at render time spheres appears to be way too low.
I've switched to "blob" shapes but now they are way too high (even when setting the blob blend to 0).
Where can i find this setting ?
Ice spheres/blobs resolution
Werner
Re: Ice spheres/blobs resolution
Why don't you use and instance sphere object with the exact res u want?
spheres and blobs always render perfectly smooth.
For spheres, if you don't want perfect smoothness plug integer value -> Setdata Self.ShapeResolutionU->execute
Dont know if there is a way to control blobs tho...
Thank you very much it works, sometimes i don't see what is in the front of my nose ! (french expression)
Werner: Thanks but this was my last solution, instance spheres isn't a good solution for me in this case because my Ice tree has many states and different size of particles, it's a liquid with gaz(air bubbles), somes need more definition and others don't.
Just for a record,
there is a way to control Blob resolution
set data. BlobCellSize (plug scalar)
its undocumented and unsupported but works.
