MetaSL
iamVFX
MetaSL
Post by iamVFX » 06 Jan 2011, 10:30
In this (http://media.fxguide.com/fxguidetv/fxguidetv-ep087.mov, scroll to half way) video Hakan Andersson talks about mental mill, si has support MetaSL shaders, but this ability was blocked in final release, how can unblock this feature, something like xsi_unsupported_metasl=1 , where is that?
Re: MetaSL
Post by Hirazi Blue » 06 Jan 2011, 12:00
much later edit (to avoid unnecessary confusion):
The correct procedure you'd have to follow is outlined
in the blog entry Stephen Blair references two posts down... ;)
iamVFX
Re: MetaSL
Post by iamVFX » 06 Jan 2011, 14:15
Thank you, Hirazi! I will surely test it soon..
Re: MetaSL
Post by xsisupport » 06 Jan 2011, 14:15
// Steve Blair
Re: MetaSL
Post by Hirazi Blue » 06 Jan 2011, 14:37
Can the re-registering of the mentalray.dll you mention in your blog
also be done within the setenv.bat?
Or is it a one-time operation?
Re: MetaSL
Post by xsisupport » 06 Jan 2011, 15:06
Hirazi Blue wrote:Can the re-registering of the mentalray.dll you mention in your blog
It's a one-time thing.
Unless you unset the env var, In that case, I think you might have to reg the dll again when you re-set the env var.
PS runonce uses cmdreg.
// Steve Blair
Re: MetaSL
Post by Hirazi Blue » 06 Jan 2011, 15:31
Thanks for the info ;)
Re: MetaSL
Post by luceric » 06 Jan 2011, 17:37
MetaSL has never been tested. We don't know if it works, if the scenes save correct, etc,
so use at your own risk
