Post
by Hirazi Blue » 02 Jan 2011, 18:58
Sorry, I probably do not understand your question.
Do you perhaps mean you downloaded an ICE-compound, a XSIAddon or something like that & you ended up with a file with a "XML" extension?
If so: this is a well-known problem with many browsers. Files are automatically saved with the "XML" file extension and should be renamed with the correct file extension manually.
So for example the ICE compound "Fill_Volume_Evenly.1.1.xsicompound" gets renamed by your browser to "Fill_Volume_Evenly.1.1.xml". Before you can use it in Softimage you must rename the downloaded file to "Fill_Volume_Evenly.1.1.xsicompound".
The same goes for addons ("xsiaddon")
& render tree compounds ("xsirtcompound")
If this is not what you mean: please say so & try to explain your problem a little better! ;)
