Slice edge and separate parts?
iamVFX
Post by iamVFX » 24 Dec 2010, 17:20
Hi everybody! Is there in SI ability to select edges and slice object on two parts? Maybe some of you know a script or one-button tool (except http://www.kai-wolter.com/resources/xsi/meshslicetool)?
iamVFX
Re: Slice edge and separate parts?
Post by iamVFX » 28 Dec 2010, 15:16
Nope? well .. Thank you! \:D/
Post by Hirazi Blue » 28 Dec 2010, 15:45
What was your problem with the meshslicetool?
This was the only one I could think of myself... ;)
Post by rray » 28 Dec 2010, 15:45
Not sure what you exactly mean - for doing it manually there's always the option to split the selected edges with the disconnect command, and then use polygon island selection to extract the parts for the other object.
For a 1 click solution I don't think this can be automatically done - for more complex objects at least where it's not possible to identify the specific halves.
iamVFX
Post by iamVFX » 28 Dec 2010, 17:49
Hirazi Blue wrote:What was your problem with the meshslicetool?
no problems so far :ymsmug: just wanted to know, did i have any other tools for situation like that
rray wrote:For a 1 click solution I don't think this can be automatically done - for more complex objects at least where it's not possible to identify the specific halves.
hmm, i think about that too, but actually with some help of symmetry plane and little bit of logic... it's possible.. but the goal is not so spectacular /:)
Happy holidays! rray, your site is Epic Win, Hirazi thanks for this forum, many good stuff i found here, you rocks guys! SI community rocks! :ymhug:
iamVFX
Post by iamVFX » 29 Jan 2011, 14:34
Guys, i found it! Plugin called "Dafeng Island Separation", found on blog of Xie Dafeng, he is Chinese.
Link for download: http://cid-7afcd5fb0cec7898.office.live ... siaddon.7z
:-bd
Post by Hirazi Blue » 29 Jan 2011, 17:00
Interesting...
Alternatively, this tool is also available in the Plugin section over at the dreaded Area...
Dafeng Island Seperation 1.3 (requires Area login)
