keep translation active
scrog
Post by scrog » 07 Dec 2010, 21:02
How do i keep the translate tool active and make another selection.
I have tried holding down the space bar ,but it is not working it deselects everytime.
craft
Re: keep translation active
Post by craft » 07 Dec 2010, 21:14
assuming you have the translate tool locked (press and release the "v" button), press and hold one of the following:
- T, to rectangle select points
- E, to rectangle select edges
- I, to raycast select edges
- U, to raycast select polygons
- Y, to rectangle select polygons
- SPACE, to rectangle select objects
release the key after the selection is done and you're back to your previous tool: the translate tool.
scrog
Post by scrog » 07 Dec 2010, 21:30
thanks, that was too easy.
I wish I would have found this community a while ago, you guys are so helpful.
grahamef
Post by grahamef » 07 Dec 2010, 22:53
You might also want to set your preferences: File > Preferences, expand Tools, click Transform, and set Click Outside Manipulator to "Select Tool".
scrog
Post by scrog » 09 Dec 2010, 19:39
speedy answers, thank you guys very much.
I am slowly getting around in xsi , but starting to see it is a great app. :-bd
